Upload files to CUCM via SSH CUCM 12.x
Alex Ribas
Is it possible to upload files via SSH direct to CUCM 12.x for service via ssh?
In other words without using the Call Manager GUI TFTP file management because the is 389Mb, instead use a SFTP client/server to transfer files to proper directory on CUCM TFTP server.
Any clue?
Alex
2 Accepted Solutions
As @Nithin Eluvathingal wrote you’re doing this the wrong way. The COP file is meant to be installed on each server in your CM cluster, not uploaded into the TFTP server as such. This is clearly outlined in the readme file for the COP file.
Response Signature
8 Replies 8
What files are you uploading to CUCM ?
AFAIK there is no such option to copy files to CUCM using SSH command as you expect. There is no SFTP sever running on CUCM.
But you can download files from CUCM TFTP using  file get tftp
This command sends a TFTP file to another system by using SFTP.
Below mentioned are the available file command.
Response Signature
Hi Thank you
The file is:
cmterm-dx650.10-2-3-26.cop.sgn and IP tftp is 172.31.1.69
I didn't find the parameter to define the TFTP server
I tried
1)    file get tftp 172.31.1.69/tftpboot/cmterm-dx650.10-2-3-26.cop.sgn
2)  file get tftp 172.31.1.69/cmterm-dx650.10-2-3-26.cop.sgn
no such file or directory can be found
But it is my tftpboot server I used it.
Any clue?
Those are firmware which must be installed on cucm using GUI OR CLI
From GUI using install/upgrade option and from cli using Utils  system upgrade initiate command.
what you are searching wound be found and you are doing it wrong.
Response Signature
Nops
The issue is the file size is 389Mb and look it.
Via GUI we have limitation 250Mb to upload.
As I mentioned above cop files must be installed and not uploaded to tftp.
Response Signature
Response Signature
Thank you all in that case I must use SFTP
Or FTP would work as well.
Response Signature
