12-16-2012 09:45 PM - edited 03-16-2019 02:45 PM
Dear all,
am using cme 8.6 in 2921 with internal Service Module (ISM) and couldn`t install the unity express 8.6.1 inside it
using filezella program.
am trying to install - cue-vm-full-k9.SPA.sme.8.6.1.prt1, (size: 138.68 MB). am facing the below error when i type
service-module ism 0/0 install url ftp://cisco:cisco@192.168.1.1/tftpserver/cue-vm-full-k9.SPA.sme.8.6.1.prt1
%Error: Couldn't open ftp://*****:*****@192.168.1.1/CISCO/tftpserver/cue-vm-full-k9.SPA.sme.8.6.1.prt1.install.sre
My pc is 192.168.1.1 connecting to gig0/2(192.168.1.2)
Here is also some info:
interface ISM0/0
ip address 192.168.200.1 255.255.255.248
service-module fail-open
service-module ip address 192.168.200.2 255.255.255.248
service-module ip default-gateway 192.168.200.1
VoiceGW#service-module isM 0/0 status
Service Module is Cisco ISM0/0
Service Module supports session via TTY line 131
Service Module is waiting for registration message
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
Module resource information:
CPU Frequency: 1068 MHz
Memory Size: 493 MB
Disk 0 Size: 4110 MB
No install/uninstall in progress
Can someone please help to solve my issue as i change the directory too of the cue file....
thanks
12-20-2012 02:20 AM
Check config and that you can reach FTP server from router.
12-20-2012 01:16 PM
you mean:
ip ftp source-interface GigabitEthernet0/2
ip ftp username cisco
ip ftp password cisco
still error.
