03-08-2012 05:58 AM - edited 03-16-2019 10:00 AM
What's the difference between the "IP SUBSET/IPSEC 64 BIT/VOICE" & "IP SUBSET/VOICE" firmwares available for the VG224 ?
I can't see any explaination in the release notes.
Does the K9 version (finally !) support SSH ?
GTG
03-08-2012 06:32 AM
Correct.
Chris
03-08-2012 06:46 AM
Hi Gordon,
You are spot on.
You need the K9 features to run SSH
Have a look at this link
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml#req
The key is this command
crypto key generate rsa
The K9 features enable this
Alex
12-30-2013 09:30 AM
Does the 64 bit version change the behavior or capacity of the voice gateway in any way other than adding SSH capability?
Bob
12-30-2013 09:36 AM
no.
Chris
