09-22-2021 12:04 PM
I have the following:
We configured all 8851 in a device pool with ISR4331 as SRST reference. We configured all VG450 ports (except two) in a different device pools with no SRST reference. Two ports are configured in the device pool with SRST reference.
I use the CUCM as a config server for the VG.
All ports of the VG receive a fallback-dn configuration from CUCM. Hence all 144 ports will try to register with the ISR when SRST occurs and battle with the 8851's for the 100 spots available.
Is there a way to restrict some VG ports to register with the ISR when SRST occurs and let some other ports register? I removed the fallback-dn configuration but as soon there a reset of SCCP, the configuration comes back. Is the only solution not to use CUCM as a config server?
Thank you!
09-22-2021 06:52 PM
Assign the ports which you dont want to register with the ISR 4331 in a different Device pool which has no SRST preference.
09-22-2021 10:46 PM - edited 09-22-2021 10:47 PM
@Nithin Eluvathingal This is already done by the OP.
”We configured all 8851 in a device pool with ISR4331 as SRST reference. We configured all VG450 ports (except two) in a different device pools with no SRST reference. Two ports are configured in the device pool with SRST reference.”
AFAIK the SCCP controlled ports will not get the SRST reference from the device pool. For these to register with SRST you’ll need to add a SCCP reference that has a higher preference than the CMs. So if you have 3 CPE CMs that would be used for normal operations you’ll add a 4:th SCCP reference that points to your router that runs SRST with a preference of 4.
With this the answer to your question would be AFAIK you cannot control what ports that can register with SRST.
09-23-2021 05:00 AM
Thank you @Roger Kallberg , I configured the router as preference 4 in the SCCP config indeed. You are telling me what I was thinking: the VG is a whole device and its ports will battle for SRST with no control. And they will battle with the 8851.
09-23-2021 06:46 AM
This docuemnt is for iOS 15.X, I didn't find an updated document for IOS Xe. so I hope the same policy gets applied to Vg450.
09-23-2021 06:54 AM
Thank you @Nithin Eluvathingal, this is good information. That is confirming with no doubt that the whole VG will try to register to SRST gateway.
09-23-2021 06:50 AM
I missed that in the OP.
