02-06-2013 05:23 AM - edited 03-16-2019 03:33 PM
i have a problem with my current configuration.
This is my setup:
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: Hw Revision: 1.0"
PID: CISCO2921/K9 , VID: V07 , SN:
NAME: "2nd generation two port BRI voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation two port BRI voice interface daughtercard"
PID: VIC2-2BRI-NT/TE , VID: V03 , SN:
NAME: "2nd generation two port BRI voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation two port BRI voice interface daughtercard"
NAME: "2nd generation two port BRI voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation two port BRI voice interface daughtercard"
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
PID: VIC3-4FXS/DID , VID: V03 , SN:
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64 , VID: V01 , SN:
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR , VID: V01, SN:
NAME: "High Density Voice2 Network module with no board interface on Slot 1", DESCR: "High Density Voice2 Network module with no board interface "
PID: NM-HDV2 , VID: V02 , SN:
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 1 SubSlot 0", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
NAME: "Internal Services Module with Services Ready Engine on Slot 0", DESCR: "Internal Services Module with Services Ready Engine"
PID: ISM-SRE-300-K9 , VID: V02 , SN:
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC , VID: V03 , SN:
The problem is, that there arent't any voice-ports for the VIC3-4FXS/DID-Module inserted in NM-HDV2 /SM-NM-ADPTR.
But without the voice-ports i cant configure any fax-ports.
Here is the output from my configuration:
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
voice-port 0/0/0
translation-profile incoming amt-rein
translate calling 2
translate called 1
no comfort-noise
cptone DE
voice-port 0/0/1
translate calling 2
translate called 1
no comfort-noise
cptone DE
voice-port 0/1/0
translate calling 2
translate called 1
no comfort-noise
cptone DE
voice-port 0/1/1
translate calling 2
translate called 1
no comfort-noise
cptone DE
voice-port 0/2/0
translate calling 2
translate called 1
no comfort-noise
cptone DE
voice-port 0/2/1
translate calling 2
translate called 1
no comfort-noise
cptone DE
voice-port 0/3/0
station-id name Fax 1
station-id number 1033
voice-port 0/3/1
station-id name Fax 2
station-id number 1034
voice-port 0/3/2
station-id name Fax 3
station-id number 1035
voice-port 0/3/3
The voice ports for voice-card 1 are missing
Do you have any hints?
Kind regards
Andre Lahl
02-06-2013 06:12 AM
Update:
I found this logging messages:
*Feb 6 13:12:47.047: %DSPRM-3-INSUFFICIENT_DSP:
voice-port : 1/0/1 Not initialized due to insufficient DSP resources
voice-port : 1/0/2 Not initialized due to insufficient DSP resources
voice-port : 1/0/3 Not initialized due to insufficient DSP resources
voice-port : 1/0/4 Not initialized due to insufficient DSP resources
It seems that there are not enough DSPs for this card. But i configured voice card 0 as a dspfarm. Isn't this working?
02-06-2013 09:23 AM
I think that NM-HDV2 does not supports VIC3-4FXS/DID.
You should use EVM-HD-8FXS/DID and NM-ADPTR for FXS.
02-06-2013 10:08 PM
thank you for your reply.
The same problem appears when i install the VIC2-2BRI-NT/TE in the NM-HDV2. There is no difference. Then i am missing the two Voice-Ports for those BRI-Ports in the module.
