Voice Translation rule query
singh-ashok
Can voice translation rules be configured on both MGCP & H.323 gateways? Or is there some protocol-based restriction?
2 Accepted Solutions
Nope. MGCP uses centralized dial-plan which all resides in CCM.
You do not use Dial-peers with MGCP
Please rate all useful posts
As above, dial-peers won't work on an MGCP gateway as all call intelligence resides on the callmanager in this setup. If you're MGCP gateway is configured for SRST then yes you'll dial-peers.
5 Replies 5
singh-ashok
Thanks a lot Darren. This is what was puzzling me. I had seen dial-peers on an MGCP gateway once. Now I do recall that the router was configured for SRST too.
Have a nice day.
Ashok.
Ayodeji Okanlawon
Its not going to work on MGCP. Because MGCP pots ports in under callmanager control, any rule defined is ignored. So you can only use it with H.323.
HTH, pls rate useful posts
Thanks Deji,
On more query. Can you configure dial-peers on MGCP gateways ?
Ashok.
