VoiceGateway SRST mode with Cisco IP Phone 8811
May Simpson
Hi All.
I'm a newbie on UC and I would like to have some advices from experts here.
We are implementing a Voice Gateway in our client site, Japan office. The CUCM(ver. 10.5) is located in another country in EU.
Our client want us to configure SRST mode on the Voice Gateway in their office. The IP Phone model is CP-8811-K9=. (Cisco IP Phone 8811).
As far as I know, SRST mode works with only SCCP and Cisco IP Phone 8811 is using only SIP.
So can't we get it to work SRST mode with Cisco IP Phone 8811? Please advice.
Mayumi Fujiwara
Manish Gogna
Hi Mayumi,
Both SCCP and SIP phones are supported with SRST, 881 is also supported. Please check the following link for supported endpoints and platforms
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/requirements/guide/srs105spc.html
For config info plz check the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide/srst_overview.html#pgfId-1469070
Manish
- Do rate helpful posts -
Thanks Manish,
Relieved to know that, I will refer to these links.
Thank you,
Mayumi
Jaime Valencia
No, you're wrong, SRST works in SCCP and/or SIP mode, the same SRST config guide covers both. Refer to the SRST compatibility guides to see what version is required for that phone model
java
if this helps, please rate
Good to hear that, thank you Jaime-san.
I will refer to the guides.
Thank you,
