10-28-2017 01:58 AM - edited 03-17-2019 11:30 AM
Hi all,
As a beginner in VOIP, i ask you please if you can guide me how to prepare a voip solution for an SMB office with 15 users. I mean, what I should choose (CUCM or CME, Type of router, which cards i have to add to the router) ?
Solved! Go to Solution.
10-30-2017 04:31 AM - edited 10-30-2017 04:32 AM
15 users, forget about call manager, go call manager express. 15 users a single or double BRI would do, but look into using an ITSP.
cisco ISR 4321 is the cheapest one that will probably fit your requirement
10-28-2017 12:12 PM
I would suggest engaging with a cisco partner or your cisco account manager to help you design out a solution that will meet your needs.
if you want to research you can start by googling the data sheets for the 4300 4400 routers series and other routers that support cucme. There are also hosted and hybrid solution like spark and or on prem cloud configure be something k.
if I where you I would start by coming up with a list of requirements for your voice infrastructure or must have from a feature standpoint and then engage with a partner/ account manager.
things to think about?
what will my pstn connectivity be, sip, h323, pots, pri
how many lines will each phone need?
do I need voicemail?
are there special greetings that need to play during certain situations?
10-30-2017 05:01 AM
THank you so much for advices
10-30-2017 05:03 AM
