VoIP over VPN Design
angel-moon
Level 3
Level 3
All,
I have a need to replace a VPN concentrator with another device.  The need is to terminate 10-20 VPN tunnels.  Voice and Data will be running over both.  The connections are using the Public Internet (no comments please, I already know).  Given this scenario would an ASA be best used to terminate the VPN tunnels or a router?
Thanks in advance.  All replies rated.
Chris Deren
I would definitely recommand ASA over ISR router for VPN, you can also use it for direct phone VPN connections.
HTH,
Chris
Chris Deren
HTH,
Chris
