VOIP Setup
amatorjnr
I'm new to this organization and their cisco switch setup is giving me a headache.
we have Voip setup with vlans and all, but the ports carrying voip have been set as trunk ports. I want to make them normal access ports that can carry voice traffic. But whenever i do so, the phones refuse to register.
This is the current setup of a voip port:
interface GigabitEthernet1/0/10
switchport trunk native vlan 21
switchport trunk allowed vlan 20,21
switchport mode trunk
switchport voice vlan 20
spanning-tree portfast
This is what I did:
no switchport trunk native vlan 21
no switchport trunk allowed vlan 20,21
switchport mode access
switch access vlan 21
But it shows phone unregistered.
VLAN 21 = data vlan
VLAN 20 = voice
the native vlan on the real trunk link is vlan 1
why does it work when the interface is a trunk but doesnt work when i change it to my configuration?
Switch is a cisco 2960 and IP phone is a CP 7821
Adam Pawlowski
Not all platforms support voice VLAN functionality without specifying the port mode is trunk. For some it's just an advertisement and needs configuration, and for others it configures it to accept that tagged traffic.
If what you've changed it to doesn't produce anything useful then configure it back the way it was.
8 Replies 8
Leo Laohoo
There are a few VoIP brands that need be on Trunk ports.
if you enable LLDP on switch and with  voice and data vlan configuration  all most all phones will work. some may need trunk.
can you specify the phone model which you are using and switch details.
Response Signature
It's a cisco cp7821 model IP phone
Hope you are using Cisco witch.
try below.
Default interface GigabitEthernet1/0/10
if this is not a Cisco switch, turn on LLDP.
Response Signature
Already did that. The device is stuck at not registered
Whats ur call control platform.
Whats the operational vlan and ip address on phone. also share the status message from phone.
is this for just one phone or all ? hae you tried resetting the phone ?
Response Signature
Is the phone getting a valid IP address or not?
Adam Pawlowski
