VTSP: Internal Error (DSP unknown failure)
We have a CUCME connected to the ITSP via a SIP trunk. Some incoming calls fail with cause code 172. In the debugs I could see this just before the SIP BYE message:
%VOICE_IEC-3-GW: VTSP: Internal Error (DSP unknown failure): IEC=1.1.182.9.22.10
#show voice iec description 1.1.182.9.22.10
    IEC Version: 1
    Entity: 1 (Gateway)
    Category: 182 (Hardware Resources Unavailable)
    Subsystem: 9 (VTSP)
    Error: 22 (DSP unknown failure)
    Diagnostic Code: 10
The call-leg on the SIP trunk is always alaw, internally between CUCME and CUE or the phones is always ulaw. We have a transcoder active.
What debugs can I run to check if this is a DSP allocation error, or if there is a hardware issue, or... ?
Thanks!
Ayodeji Okanlawon
You can use
show voice dsp group all..
This will show if you hava had dsp allocation failure
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Thanks aokanlawon, I don't have access to the customer network right now but i'll try this and let you know the output soon.
Hi aokanlawon
It doesn't look like a DSP allocation issue:
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 26.3.7
  Max signal/voice channel: 43/43
  Max credits: 645
  num_of_sig_chnls_allocated: 42
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 630, reserved credits: 0
    Signaling channels allocated: 42
    Voice channels allocated: 1
    Credits used (rounded-up): 15
    Voice channels:
      Ch01: voice port: 0/2/0, codec: g711alaw, credits allocated: 15
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 2:
  Max credits: 645
  num_of_sig_chnls_allocated: 17
  Transcoding channels allocated: 12
    Shared credits: 403, reserved credits: 0
    Signaling channels allocated: 0
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Group: FLEX_GROUP_XCODE, complexity: MEDIUM
    Shared credits: 0, reserved credits: 242
    Credits used (rounded-up): 21
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 3:
  Max signal/voice channel: 42/43
  Max credits: 645
  num_of_sig_chnls_allocated: 0
Shared credits: 645, reserved credits: 0
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
DSP groups on slot 3:
This command is not applicable to slot 3
DSP groups on slot 4:
This command is not applicable to slot 4
  0 DSP resource allocation failure
Any idea?
Thanks!
FYI: the issue did not reoccur so far...
