04-09-2013 12:06 PM - edited 03-16-2019 04:42 PM
i have 2921 H323 gateway with IOS
c2900-universalk9-mz.SPA.152-3.T.bin , EI is connected over VWIC3-2MFT-T1/E1
interface but in or out calls over the E1 don't work ,
this router was placed instead of 2811 gateway with IOS c2800nm-advipservicesk9-mz.124-24.T2.bin with interface VWIC2-2MFT-T1/E1 in this case the calls was working normal ,
but when we replace 2811 with 2921 with the same configuration calls not working on 2921 ,
any one can help please ?
04-09-2013 12:14 PM
Please describe your setup..
cucm--h323--gateway--e1--PSTN or
cucm--mgcp---gateway--e1--PSTN
Can you also send your sh run
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-09-2013 12:57 PM
Hi.
Is the isdn link established with your telco.
Please provide also a show isdn status.
Carlo
04-09-2013 02:27 PM
you need to enable your E1 interface
card type E1 0 0
Anas
please don't forget to rate the helpful posts
04-09-2013 08:04 PM
Hi Marzok,
IOS Toll Fraud Prevention could be one of the problems since IOS has also changed in addition to router model and Fraud prevention was introduced.
Please refer URL:
https://supportforums.cisco.com/docs/DOC-25099
regds,
aman
04-09-2013 11:09 PM
Hi Marzok,
Please issue the commands
show ip address trusted list to check for IPs that are blocked.
To allow source IPs/all IPs , u can follow commands
a.
voice service voip
ipv4 0.0.0.0 0.0.0.0
b.
voice service voip
no ip address trusted authenticate
regds,
aman
