What is PVDM3-64U256?
jaameshaale
I am confused on what PVDM3-64U256 is.   The description says "PVDM3 64-channel to 256-channel factory upgrade".  Is this some sort of upgrade from 64 to 256?
How is this different from PVDM3-64 and PVDM3-256?
James
2 Accepted Solutions
Brian Meade
Level 7
Level 7
Basically, the router you ordered came with a 64-channel card and this is an upgrade product key to a 256 channel card.  It is cheaper than buying a 256 channel card as they're subracting the cost of the 64 channel card.
Cost is a wash, but they don't send you the PVDM3-64, all you get is 256.  This is just an incremental part number to a bundle which would include PVDM3-64.
Chris
6 Replies 6
Brian Meade
Level 7
Level 7
Thanks.
So, essentially I am purchasing a 256 channel card at a lower price.  Once I recieve the card, I would have to physically take the 64 out and replace it with 256.  Correct?
Chris
Ahh... it makes sense now...
Thanks Chris
Chris,
I was using the Configurator and was making a Quotation for CISCO3925-SEC/K9 Router, it includes PVDM3-64 and if I upgrade it in the configurator to buy a PVDM3-64U256, then PVDM3-64 is not showing in the final BOQ. Please let me know do I have to purchase PVDM3-64 separately or is in included in PVDM3-64U256?
Farhan
Syed,
If you have chosen the PVDM3-64U256, then you will get the PVDM3-256. If you want PVDM3064, then just select that or leave the default bundle, because this is included in the bundle
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
