Which version we should use when upgrading to version 8 of CUCM?
nixonlawbi
Beginner
Beginner
Dear Support Community,
We are planning to upgrade our CUCM from version 6.14 to version 8.0X or 8.X. Which version would you recommend and why? Stability is our main concern.
Thanks.
Roman Rodichev
Rising star
Rising star
Go to 8.5, it will be more stable, think of it as a minor upgrade of 8.0. It's not called 8.1 because Cisco wanted to synchronize version numbers between a bunch of products.
Also make sure your other Cisco voice apps are compatible with 8.5.
Edit: note that both latest 8.0 and 8.5 are stable releases
Roman Rodichev
Rising star
Rising star
Hi Roman,
Thanks a lot for your valuable feedback! Should we go with the SU1 or only 8.5(1) in your opinin?
No problem!
Always use latest updates
