Who ended the call firstly?
a6z69@yahoo.com
Dear Guru,
                We have a lot of agents has short calls and we need to know Who ended the call from agent side or from the customer side ?
Cisco CUCM 12.5
Cisco UCCX 12.5
Standard License
5 Replies 5
Look at the SDL logs in CM. This is visible in them. Possibly there are also some report(s) in CIUC where you can see this.
Response Signature
What's the advantages of SDI here ?
Kindly clarify ?
The SDL logs contains information about all calls, including whom ended it.
Response Signature
To add a tip to what @Roger Kallberg  suggested also  in CDR , searching for origCallTerminationOnBehalfOf you can find who termiated a call. If a phone (Agent) terminates a call, the value of that parameter is 12.
Carlo
Please rate all helpful posts "The more you help the more you learn"
grebac.2ring
Level 5
Level 5
2Ring Gadgets for Cisco Finesse offers an interaction history gadget that's available inside of Cisco Finesse, and it shows this information to supervisors - along with details of each interaction and agent state history. Please see a screenshot below + more information is available at these two links:
https://www.2ring.com/products-manager/gadgets-for-cisco-finesse/features/#agent-interaction-history
https://www.2ring.com/products-manager/gadgets-for-cisco-finesse/features/#agent-state-trace
To learn more, please request a demo at www.2Ring.com/Webex Thank you.
