Why do I get this debug (voice), even if I undebug all.
Hi all,
I am workiong in my router from a telnet terminal, I needed to do some debugs, but every time y use de "term moni" commando, I get those lines when a call is finished.
175139: Aug 29 22:20:11: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 80DD50F5F0E9E103DF003D05A021522, SetupTime 22:20:00.475 GMT-7 Wed Aug 29 2012, PeerAddress 804375103, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 22:20:07.485 GMT-7 Wed Aug 29 2012, DisconnectTime 22:20:11.265 GMT-7 Wed Aug 29 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 200, TransmitBytes 32000, ReceivePackets 0, ReceiveBytes 0
175140: Aug 29 22:20:11: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEATURE_VSA=fn:TWC,ft:08/29/2012 22:20:00.473,cgn:804375103,cdn:9018001232222,frs:0,fid:85993,fcid:80DD50F5F0E9E103DF003D05A021522,legID:14FE9
175141: Aug 29 22:20:11: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 80DD50F5F0E9E103DF003D05A021522, SetupTime 22:20:00.751 GMT-7 Wed Aug 29 2012, PeerAddress 9018001232222, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 22:20:07.481 GMT-7 Wed Aug 29 2012, DisconnectTime 22:20:11.341 GMT-7 Wed Aug 29 2012, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 200, ReceiveBytes 32000
175142: Aug 29 22:20:11: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEATURE_VSA=fn:TWC,ft:08/29/2012 22:20:00.477,cgn:804375103,cdn:9018001232222,frs:0,fid:85994,fcid:80DD50F5F0E9E103DF003D05A021522,legID:14FEA
It is really anoying, I've tried these commandos.
logging buffered 51200 warnings
and the
undebug all
still get those lines.
Could you help me with this?
Reggards
This is te info of my router.
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.4(4)XC7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 01-Aug-07 02:10 by alnguyen
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
gwhervpn uptime is 9 weeks, 2 days, 9 hours, 30 minutes
System restarted at 12:56:38 GMT-7 Mon Jun 25 2012
System image file is "flash:c3825-spservicesk9-mz.124-4.XC7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.0) with 220160K/41984K bytes of memory.
Processor board ID
2 Gigabit Ethernet interfaces
4 Serial interfaces
1 terminal line
4 Channelized E1/PRI ports
4 Voice FXO interfaces
1 cisco Integrated Service Engine(s)
   Cisco Unity Express 3.2.2 in slot 2
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62592K bytes of ATA System CompactFlash (Read/Write)
jasyoung
Level 7
Level 7
Juan,
It's not a debug output. CDR logging to syslog is a configurable option and you seem to have it turned on. Look for the command "gw-accounting syslog" or similar in your running config, and remove it.
6 Replies 6
Chris Deren
What do you see when you issue "show debug"?
I would recommend upgrading IOS as this is very dated version and in fact one that was never very popular and widely deployed/recommended. I recommend 15.1.4M train.
HTH,
Chris
You can check whether any debugs are still enabled using the command 'show debug'.
jasyoung
Level 7
Level 7
Juan,
Thank you jasyoung!
It disapeared with that
5 stars
I have a new client and these logs were driving me NUTS!  'no gw-accounting syslog' did the trick!
Thanks!
bbhattacharya
I had the same issue and removing "no gw-accounting syslog " helped me as well. Thank you jasyoung.
