Showing results forĀ
Search instead forĀ
Did you mean:Ā
Why I can not get accounting file from gw by ftp?
benzhao98
Below is warnng
#WARNING: gw-accounting fact not enabled. return.WARNING: gw-accounting fact not enabled. return.
13 Replies 13
benzhao98
Below is my configurations
gw-accounting file
primary ftp 164.4.249.82 username ben98 password 123456
maximum buffer-size 40
maximum fileclose-timer 60
maximum cdrflush-timer 45
cdr-format compact
I have the exact same issue on ISR2811 with 12.4.24 (T). were you able to figure out what the problem was?
CSCtb72550 Bug Details
Call Detail Record File not created in FTP  Server
Symptoms: Call Detail Record (CDR) files  pushed via FTP are  not created on the FTP server.
Conditions:  This  symptom is observed when the gw-accounting file command is  configured to point to an FTP server.
Workaround:    Push the CDR records locally to the flash instead of to an FTP URL
is there a way to periodically move the file from flash to fTP?
No.
Well - you could maybe use a scheduled EEM script to copy the output file?
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
So to avoid a simple image upgrade one starts tinkering workarounds ?
Now now... question was 'could I', no 'should I'...
In that sense, Expect scripting predates EEM by 20 years, and work great.
But fortunately, not even Cisco dares to suggest that as workaround.
wow ok. so the best option is to upgrade. do you know if this has been fixed in 12.4.22YB4? thanks a lot for all your help guys.
Hi Kris,
Just an FYI 12.4.22YB4 is in the "known affected version list" as shown in the link below
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtb72550
Here are the "fixed-in" versions
Fixed-In
15.1(0.21)T
12.2(32.8.11)SX332
12.2(32.8.11)YST273.11
12.4(24)YE
15.1(24.6.26)PIL13
15.0(1)M1.7
15.1(0.2.12)PIB13
12.4(25b)M0.18
12.4(24)T3
15.1(1)XB1
15.1(0.0.10)PIL14
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Hi, everyone.
I have the same problem.
My IOS version is Version 15.1(4)M4
And I cant send the CDR files  to the FTP Server.
Here is are my commands:
gw-accounting file
primary ftp :[]/BibCme1/cdrtest1 username password
secondary ifs flash:cdrtest2
acct-template callhistory-detail
maximum buffer-size  25
maximum retry-count 5
maximum fileclose-timer 500
maximum cdrflush-timer 445
cdr-format compact
Where:
is the address of my FTP Server;
/BibCme1 is the FTP (See the image)
cdrtest1 is the filename.
Putting the CDR on flash memory works, but I cant get it to work on the FTP Server that I need to configure the billing software (BillyBlues - Stonevoice Application Suite 2012).
Any help??
Or is there a way that I can copy the CDR from flash to FTP Server???
I have added the following command to force CME to send CDRs to BillyBlues too:
file-acct flush with-close
But I still cant do it.
Any help?
Edson Vuma
-- Regards Edson Vuma
Network's Dust
Please try this:
R(config)#gw-accounting file
primary ftp BillyBlues_IP/billyblues/ username usr password pwd
maximum buffer-size 6
maximum retry-count 4
maximum fileclose-timer 300
where
ā€¢ BillyBlues_IP is the IP address of the BillyBlues machine
ā€¢ usr/pwd is the username/password of the local Administrator on the BillyBlues machine.
The following command to force CUCME to send CDRs to BillyBlues:
R# file-acct flush with-close
R# file-acct reset
