Metro
Labels
Hello everyone! I'll appreciate it if anyone can help me! I have a router ASR 1002 and I need to configure a PPPoE server in this ASR, but when I configured the machine I realized that the PPPoE server was apparently normal. The client is connected, ...
Hi, Guys, I'm a beginer with NSO, and now i want to re-deploy a service to fix the broken configs, but i can't remove any other out-of-band configs that have been made to the device, what command or step i should do to implement this? Any help will b...
Steven4699 by Frequent Visitor
  • 2675 Views
  • 1 replies
Hi, Guys, For Cisco NSO, i'm going to undeploy a service instances, dose it remove the service configuration from the both network and NSO??? Thanks!
  • 2370 Views
  • 1 replies
Now that Cisco has acquired Accedian network I can seem to find a manual for a AMN-1000-TE device.  Anyone know where to find one of these?
rosbor1 by Frequent Visitor
  • 3152 Views
  • 3 replies
Hello,I'm facing this issue with a connection between two NCS2k-400G-XP-LC cards.Site A has Remote fault on port 8-1 and Site B has SIGLOSS on port 8-1. Both ports have QSFP-100G-SR4-S plug-in to them. I tried to replace the MPO cables, the cards the...
muskhudhay by Community Member
  • 1584 Views
  • 1 replies
Hey, I'm running Flexible Cross-connect service over EVPN and i'm trying to establish CFM CCM over it. I'm running it in a lab, and i'm getting "configuration errors present" in the "show ethernet cfm services" but i can't tell where is the error.My ...
markk2316 by Frequent Visitor
  • 2485 Views
  • 1 replies
Hello and sorry for my english,How i can find if my routeur C8300-2N2S-4T2X support LACP etherchannel ?(IOS : Cisco IOS XE Software, Version 17.09.03a)thanks a lot
mulbreizh by Level 3
  • 1957 Views
  • 1 replies
Hello,Looking for some help on this trunk config I maybe don't understand the service instance configuration on a Ncs 520 but I'm unable to see the other N520 connected to this device with these configs plugged into each other. Please let me know wha...
Adcom911 by Level 2
  • 1959 Views
  • 2 replies
  • 1 Helpful votes
Good day!I have 2 Catalyst 3650 in stack (role intervlan routing)#show versionCisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.06E And 2 ISPs provide service VLAN to remote office - VLAN ID the...
dboevets by Frequent Visitor
  • 2642 Views
  • 2 replies
  • 1 Helpful votes
