Bookmark
Subscribe
659
CiscoWorks LMS: not receveing certain SNMP traps
Marian Hercek
CiscoWorks LMS 4.0.1 (I know it's old and unsupported).
Problem: not receiving certain SNMP traps.
For example: I receive trap like "STP new root" but not like "port put to err-disabled" or my custom traps (produced by EEM scripts).
I've investigated my situation and found out that switch sends traps and they reach* LMS but somehow LMS ignores them (there's no trace of them in GUI). I've read that some traps just pass through LMS but my traps are very important and I need to know about them.
* I did Wireshark capture on LMS machine.
I'd like to know how to debug receiving of SNMP traps in LMS:
  1. which specific debugs need to be enabled,
  2. which specific log files need to be examined.
Michel Hegeraat
Level 7
Level 7
LMS uses DFM to process certain traps.
All traps it deems unimportant are dropped.
If you want to use the LMS GUI you can have you device send a SYSLOG message rather than a trap.
use logging source command to make the management interface send the message.
Then there is a GUI that allows you to launch an action on a message
Cheers,
Michel
