03-12-2013 04:20 PM
Anyone has done this direct upgrade?. Is it better to uninstall LMS 4.0 completely and then install LMS 4.2 or could I do a direct upgrade?. I've heard the db tables etc. have changed a lot and might cause problems for a direct upgrade.
Any suggestions/tips are welcome.
03-13-2013 07:56 AM
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/install/guide/overview.pdf I think there are some guidelines on here. You may need to do a point patch to 4.0.1 first.
In my opinion, (personally) it would depend on how much I had configured. In my experience, it sometimes gets flaky after a few upgrades (3.2->4.0.1>4.1>4.2). I ended up running another box parallel and added things back gradually before switching over the IP and migrating data. Even then, some of the devices were still misbehaving until I removed them and added them manually.
03-13-2013 08:40 AM
Thanks Mat. I should have mentioned, I am already on 4.0.1.
03-13-2013 01:17 PM
I'd agree with Mat re not wanting to do too many in-place upgrades - even if it's a supported path.
However 4.01 to 4.2 is a direct one step upgrade and should be fine. I went from 4.1 to 4.2 and added the .1-.3 patches on top of that.
For some reason the 4.2.x patches must be sequentially installed and aren't cumulative. So getting up to the current 4.2.3 will entail a couple of extra steps.
03-14-2013 06:52 AM
Thanks Marvin. I did read your blog on the 4.2.3 upgrade. I do intend to backup my db, export credentials, collectors etc. just in case.
A secondary question - do the net config jobs get carried over to the new version or do they all get lost?
03-14-2013 06:57 AM
You're welcome.
Alas I didn't have any netconfig jobs setup to confirm the answer to your secondary question.
