Bookmark
Subscribe
3395
Monitoring ASA Hardware health using SNMP MIB
giridar
Hi All,,
I am using Manage Engine OpManager to monitor the ASA's status, i managed to add the device successfully using SNMPv3
however it needs the correct MIB and OIDs to monitor the status of the pow supply and other hardware components
could you please advise on which MIB to use
thanks in advance
marce1000
 - Below you will find some info-resources on the matter, as I pointed out in one of the threads - low end models may not implement all MIB - features. Hardware status monitoring is probably limited too :
    https://community.cisco.com/t5/security-documents/asa-5510-power-supply-status-via-snmp/ta-p/3160793
    https://community.cisco.com/t5/network-management/asa5545-x-power-supply-monitoring-with-snmp/td-p/3786102
   https://community.cisco.com/t5/network-security/asa-5512-monitor-power-supply-status-via-snmp-oid/td-p/2602908
 M.
thank you I have 5525
balaji.bandi
if you do not have corrct MIB or OID download from below URL :
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2
you can look below :
1.3.6.1.2.1.47.1.1.1.1.2.11 = "Chassis Cooling Fan 1" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.12 = "Chassis Cooling Fan 1 Sensor" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.13 = "Chassis Cooling Fan 2" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.14 = "Chassis Cooling Fan 2 Sensor" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.15 = "Chassis Cooling Fan 3" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.16 = "Chassis Cooling Fan 3 Sensor" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.17 = "Power Supply 0" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.18 = "Power supply 0 Presence Sensor" [ASN_OCTET_STR]
1.3.6.1.2.1.47.1.1.1.1.2.19 = "Power Supply 0 Input Sensor" [ASN_OCTET_STR]
BB
