PI 3.3 - internalSchedule Job Issue
nixpengu1n
Hello, all
I've recently installed PI 3.3 and configured it (as much as possible) according to Admin and User Guide. However I am facing with a strange Job Scheduler issue - some job is keep failing and giving me this error:
However under Administration -> Job Dashboard I can not see any failed jobs. Everything is green or on stop. Does anyone come across such issue? My problem is - I am a bit confused where to check this job and modify / stop it (as it seems this is some internal PI job).
Thank you in advance.
17 Replies 17
kkolander
Has anyone an explanation or a solution for this problem?
I see 18 people have this problem too.
mpofut0901
I installed Prime Infrastructure 3.3.1 Maintenance Release file PI_3_3_1-1.0.15.ub and the issue has been resolved now:
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-3-1/release/notes/cpi_rn.html
I am experiencing this same issue as well using Cisco Prime Infrastructure 3.4 build 3.4.0.0.348.  Latest Device Pack 3.  Same issue.  Anyone able to fix their issue with this?
jegan_rajappa
I am seeing same problem in 3.4.0.
I discovered my issue was happening due to I had a node that was not polling properly.  After I corrected the issue with the faulty node, this went away.  Recommend checking your nodes to make sure they are all polling correctly.
What change did you made in your polling config?
ferenc.vissers
Experienced same in PI 3.4.1 and now in 3.5.
Same on version 3.8
Regards.
is there any update on this? I am also running PI 3.8, the inventory is up to date, so there doesn't seem to be an impact on services, apart from the major alarm.
Kind regards,
Katerina
Which device parameters need to be checked to get rid of this ?
Kind regards,
Wini
Never got an answer, fix, etc. PI was part of a lab that has since been re-purposed, so it was never pursued further from my end.
don.click1
Level 4
Level 4
we just moved to 3.10 and it is STILL occurring. Come on Cisco - fix it already. How many releases are you going to push before you actually look at what your customers are asking for?
is that the same 'job failed three consecutive times' error message ?
