Prime Infrastructure CLI Template Clean IOS-XE Not Working
Shrimpy
I'm currently using PI 3.9 Patch 1, to send an interactive command to all my switches (9300 & 3850) but it fails every time. I usually have less issues when I perform "install remove inactive" on all my switches before upgrading them with prime. I was hoping to use prime to send that command, so I can make it easy. However, it keeps failing.
My CLI template:
#INTERACTIVE
install remove inactive<IQ>Do you want to remove the above files? [y/n]<R>y
#ENDS_INTERACTIVE
Error message:
Error occured while executing the command install remove inactive.Command Output : install remove inactive
% Invalid input detected at '^' marker.
9300 - 16.12.04
3850 -  16.9.6
Any one have anyluck with using prime to "clean" switches?
yajimene
By default commands will run on config mode. In this case, this command should be entered under Priv EXEC mode (enable).  So you need to add an additional tag to let Prime Infrastructure know this command will be configured on "enable" mode:
#MODE_ENABLE
#INTERACTIVE
#ENDS_INTERACTIVE
#MODE_END_ENABLE
That should do the trick.
6 Replies 6
yajimene
#MODE_ENABLE
#INTERACTIVE
#ENDS_INTERACTIVE
#MODE_END_ENABLE
Yajimene,
Thank you, sure enough that did the trick. I feel dumb now, but thank you. Funny story, just got done manually cleaning a ton of switches, but this works for the future!
I am getting error when using the script that reads 'Error : Connnection timed out while executing the command'
Any idea why this error is happening?
Was having the same issue, had to modify the CLI so that the IQ section was strictly the text within the brackets, like this:
#MODE_ENABLE
#INTERACTIVE
install remove inactive<IQ>y/n<R>y
#ENDS_INTERACTIVE
#MODE_END_ENABLE
This worked for me in Prime 3.10, update 01.
Hi @yajimene
I get the same error like @Drachiri :
we have added the Hosts with the DNS Name on the PI.
@Shrimpy does it work for you like that?
Was having the same issue, see my response to Drachiri above for the solution.
