Network Management
Labels
I need some help guys! So we are tasked to figure out DHCP as a school work, and the first part is the DHCP standard. So here comes the next part, as you can see in Networks 1 and 2, they are connected and have DHCP service at Server 1. So the task t...
nixb by Level 1
  • 610 Views
  • 13 replies
I am trying to connect to GUI interface of WLC but it is continuously showing "Server Reset Connection". I configured the management interface of WLC with an IP 192.168.10.10 and PC connecting with the WLC with an IP 192.168.10.11. The PC and WLC are...
We have two Cisco ASA 5525 firewall at Block A and Block B where the failover was not setup yet. Should i need to configure one port at firewall and install new physical fiber cable with transceiver for peer to peer connection?
 Hello friends,I have a couple of Cisco Nexus 9000 C93108TC-EX chassis with the following software:BIOS: version 07.69NX-OS: version 9.3(13)Last night, one of the switches rebooted by itself, and I found the following log for the incident:  Nexus2# s...
loosing my tether with this, can't get a 4451 to talk to the CSLU. there's nothing special in the config, no vrfs etc, default route pointing out to the internet. There is no firewall blocking anything either. I can ping a hostname fine. SIPS#ping to...
Top Solution Authors
