Upgrade NCS 1.1.1.24 to Cisco Prime Infrastructure 1.2
Jurgens L
Level 3
Level 3
Having a problem installing the ncs_patch-1.1.1.24-upgrade-pi_1.2.tar.gz patch file on a virtual NCS before upgrading it to Cisco Prime Infrastructure 1.2.
I've followed the Cisco Prime Infrastructure 1.2 Quick Start Guide and did not had the same success as described in the document (see below):
gmsncs/admin# dir disk:defaultRepo/
Directory of disk:defaultRepo/
  508376482 Sep 13 2012 05:38:25  backup-20120913-0530.tar.gpg
  853768584 Sep 20 2012 05:40:17  backup-20120920-0530.tar.gpg
     127019 Sep 26 2012 16:40:58  ncs_patch-1.1.1.24-upgrade-pi_1.2.tar.gz
           Usage for disk: filesystem
                 1544204288 bytes total used
                27185573888 bytes free
                30293413888 bytes available
gmsncs/admin# patch install disk:defaultRepo/ncs_patch-1.1.1.24-upgrade-pi_1.2.tar.gz defaultRepo
Save the current ADE-OS running configuration? (yes/no) [yes] ? yes
Generating configuration...
Saved the ADE-OS running configuration to startup successfully
Initiating Application Patch installation...
% Local file not found
Anybody experience with this procedure.
Thank You
--- Update ---
Skipped Step 4 and followed Step 5 in the Quick Start Quide, however now I receive a diffrent error:
gmsncs/admin# dir disk:/defaultRepo
Directory of disk:/defaultRepo
  926193986 Sep 26 2012 17:48:12  GRDbackup-120926-1736.tar.gpg
                 2471309312 bytes total used
                26258468864 bytes free
gmncs/admin# patch install GRDbackup-120926-1736.tar.gpg defaultRepo
% Manifest file not found in the bundle
gmsncs/admin#
