10-14-2020 02:09 PM
how can i have a router on a stick so that the router s ip (ssh/telnet) is 10.0.0.1 vlan7
the switch ip is 10.0.0.2 vlan7
AND and here where i got stuck i connect a computer to the switch ports on the router (not the switch) with ip 10.0.0.10
how do i need to set up the port for the computer
10-14-2020 02:30 PM
You can not do that unless you change the router to act as Bridge between PC and Switch.
Logically if the device in the same switch, i would provision another port in the switch with VLAN 7.
what is the goal or problem trying to solve, taking PC into Router port?
10-14-2020 02:46 PM
10-14-2020 03:01 PM
i have no IEEE
ast IBM protocol
dec DEC protocol
ibm IBM protocol
vlan-bridge vlan-bridge protocol
and it complaining that
Spanning Tree protocol for Bridge Group 7 has not been configured.
i think i can ignore that for the moment
but what protocol should i use instead of ieee
the router is a c1111
also if i do the bridging will i see traffic in netflow?
thank you so far
