vlan and management subnet
ino
how can i have a router on a stick so that the router s ip (ssh/telnet) is 10.0.0.1 vlan7
the switch ip is 10.0.0.2 vlan7
AND and here where i got stuck i connect a computer to the switch ports on the router (not the switch) with ip 10.0.0.10
how do i need to set up the port for the computer
balaji.bandi
You can not do that unless you change the router to act as Bridge between PC and Switch.
Logically if the device in the same switch, i would provision another port in the switch with VLAN 7.
what is the goal or problem trying to solve, taking PC into Router port?
BB
Hello
Try the following:
Kind Regards
Paul
i have no IEEE
ast IBM protocol
dec DEC protocol
ibm IBM protocol
vlan-bridge vlan-bridge protocol
and it complaining that
Spanning Tree protocol for Bridge Group 7 has not been configured.
i think i can ignore that for the moment
but what protocol should i use instead of ieee
the router is a c1111
also if i do the bridging will i see traffic in netflow?
thank you so far
