NDFC resource tab vlan range
Deepak Bansal
Hi Experts,
Im deploying NDFC for greenfield network. In resource tab its asking below, i don't know what this will be used for , should i keep it default value or I need to put some vlan and need to reserve it .
* Network VLAN Range
Per Switch Overlay Network VLAN Range (Min:2, Max:3967)
* VRF VLAN Range
Per Switch Overlay VRF VLAN Range (Min:2, Max:3967)
and
* Subinterface Dot1q Range
Per Border Dot1q Range For VRF Lite Connectivity (Min:2, Max:4093)
 Please share your valuable comments and recommendation.
Thanks Balaji for sharing all documents.
document doesn’t Tak about recommendations or best practice. For example
Network VLAN Range
it sound like L2 vlan range and I believe all vlan from 2 to 3967 should be in switches right. Those fields are auto populated based upon Cisco best practice. These things are missing in document.
hope it’s making sense.
appreciate your help here
