Cisco 3064-PQ-10G-X - GLC-T is not operating on 1G Speed, rather on 100mb
khizersaleem92
Hi Cisco Family,
good day.
I have a nexus 3064pq-10g-x with the current software level on version 6.0(2)U6(7). I'm facing an issue that I plugged the GTC-T transceiver on the cisco nexus switch but it is not operating on 1G, ports are showing the status " down " and "sfpabsent" even when issuing the " show interface status " command.  Doing many things even, change the duplex but the result remains the same.
But it's operating on 100mb speed.
Thanks in advance.
Best Regards
Khizer Saleem
7 Replies 7
balaji.bandi
This has capabilities to run 100/1g/10G, so it should work.
i can suggest some stesp :
1. remove SFP - default the interface config ( default interface ethx/x)
2. change the speed interface config ( speed 1000)
3. Insert the SFP
4. make sure your end device is capable of 1GB negotiation.
test and advise. - if this still now working
post below out put :
1. show interface ether x/x
2. show run interface ether x/x
3. show interface ether x/x trans
what is the end device you trying to connect?
BB
khizersaleem92
Hi Balaji
Thanks for your response.
I already perform the mentioned exercise, but the issue was the same. meanwhile please have the output of the suggested commands;
sh run int ethernet 1/38
!Command: show running-config interface Ethernet1/38
!Time: Sat Sep 26 12:21:15 2020
version 6.0(2)U6(7)
speed 100
Primary# show int ethernet 1/38
Ethernet1/38 is up
Dedicated Interface
Hardware: 100/1000/10000 Ethernet, address: 881d.fcce.1e6d (bia 881d.fcce.
1e6d)
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is access
full-duplex, 100 Mb/s, media type is 1G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped 1d19h
Last clearing of "show interface" counters 1d19h
3 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 559672 bits/sec, 213 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 502.02 Kbps, 119 pps
RX
2272 unicast packets 0 multicast packets 0 broadcast packets
2272 input packets 1541023 bytes
0 jumbo packets 0 storm suppression packets
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
386338 unicast packets 28443970 multicast packets 3605684 broadcast pa
ckets
32435992 output packets 10286609776 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 9895 output discard
0 Tx pause
show int ethernet 1/38 tr
transceiver trunk
Primary# show int ethernet 1/38 transceiver
Ethernet1/38
transceiver is present
type is 1000base-T
name is OEM
part number is SFP-GE-T
revision is
serial number is 180426560427
nominal bitrate is 1300 MBit/sec
Link length supported for copper is 100 m
cisco id is 3
cisco extended id number is 4
One more thing I want to mention that, it's operating on 1g with server and SAN on the other end, but whenever I give the uplink to cisco catalyst 2960 it shows this behavior.
balaji.bandi
this show the other end not able to handshare with 1GBps, Do you have other side config of the port
can you post other side information :
show version
show interface Gi x/x
show run interface gi x/x
show run interface gi x/x tran
BB
khizersaleem92
This is because I set the speed on 100Mb/s, meanwhile here is your required outputs
Switch#show version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 15:59 by nachen
Image text-base: 0x00003000, data-base: 0x01200000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
Switch uptime is 35 weeks, 1 day, 20 hours, 26 minutes
System image file is "flash:c2960-lanbasek9-mz.122-46.SE/c2960-lanbasek9-mz.122-46.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960G-24TC-L (PowerPC405) processor (revision E0) with 61440K/4088K bytes of memory.
Processor board ID FOC1248X28U
Last reset from power-on
1 Virtual Ethernet interface
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:24:50:0E:8F:00
Motherboard assembly number : 73-10015-06
Power supply part number : 341-0098-02
Motherboard serial number : FOC12482PWL
Power supply serial number : DCA1245928D
Model revision number : E0
Motherboard revision number : A0
Model number : WS-C2960G-24TC-L
System serial number : FOC1248X28U
Top Assembly Part Number : 800-26673-03
Top Assembly Revision Number : B0
Version ID : V03
CLEI Code Number : COM3G00BRB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 24 WS-C2960G-24TC-L 12.2(46)SE C2960-LANBASEK9-M
Configuration register is 0xF
Switch#sh interface GigabitEthernet0/9
GigabitEthernet0/9 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0024.500e.8f09 (bia 0024.500e.8f09)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:27, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 69567
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 45000 bits/sec, 14 packets/sec
5 minute output rate 332000 bits/sec, 124 packets/sec
119776819 packets input, 38971157161 bytes, 0 no buffer
Received 3985827 broadcasts (2642787 multicasts)
0 watchdog, 2642795 multicast, 0 pause input
2451917744 packets output, 1173892823021 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
Switch#sh run interface GigabitEthernet0/9
Building configuration...
Current configuration : 112 bytes
switchport mode trunk
speed 100
duplex full
channel-group 2 mode active
end
#sh interface GigabitEthernet0/9 transceiver
Diagnostic Monitoring is not implemented.
Switch#show inter transceiver dom-supported-list
Transceiver Type Cisco p/n min version
supporting DOM
DWDM GBIC ALL
DWDM SFP ALL
RX only WDM GBIC ALL
DWDM XENPAK ALL
DWDM X2 ALL
DWDM XFP ALL
CWDM GBIC NONE
CWDM X2 ALL
CWDM XFP ALL
XENPAK ZR ALL
X2 ZR ALL
XFP ZR ALL
Rx_only_WDM_XENPAK ALL
XENPAK_ER 10-1888-03
X2_ER ALL
XFP_ER ALL
XENPAK_LR 10-1838-04
X2_LR ALL
XFP_LR ALL
XENPAK_LW ALL
X2_LW ALL
XFP_LW NONE
XENPAK SR NONE
X2 SR ALL
XFP SR ALL
XENPAK LX4 NONE
X2 LX4 NONE
XFP LX4 NONE
XENPAK CX4 NONE
X2 CX4 NONE
SX GBIC NONE
LX GBIC NONE
ZX GBIC NONE
CWDM_SFP ALL
Rx_only_WDM_SFP NONE
SX_SFP ALL
LX_SFP ALL
ZX_SFP ALL
SX SFP NONE
LX SFP NONE
ZX SFP NONE
GIgE BX U SFP NONE
GigE BX D SFP ALL
balaji.bandi
I have noticed the below output, is this setup for reason?  try to remove speed and change to auto-negotiation?
speed 100
duplex full
end
BB
khizersaleem92
The following error is occurs after removing the speed and configure it on manual;
" Configuration does not match the port capability "
The issue remains the same.
Best Regards
