nexus 9k / vrrpv3 / track
nvanhaute
hi,
I would like to know how to configure tracking interface with vrrpv3 on n9k.
A (master) :
interface Vlan1145
no shutdown
ip address xxxxxx/26
vrrpv3 4 address-family ipv4
priority 110
address yyyyyyyy primary
B (slave) :
interface Vlan1145
no shutdown
ip address zzzzzz/26
and I want to track interface Ethernet 1/40 on each, so if 1/40 is down on master, A should become slave and B master. If 1/40 on A is back up, A should become master again (and B slave).
6 Replies 6
balaji.bandi
what configuraiton in place of now in nexus ? or you looking example :
here is example to get an idea how you can track and manipulate active/slave peers :
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/ios-xml/ios/ipapp_fhrp/configuration/15-e/fhp-15-e-book/VRRPv3-Object-Tracking-Integration.html.xml
BB
thanks for your reply.
but is it the same as IOS ?  in my case I want to track an interface (not the vrrp one)
I know it's different as vrrpv2, that's why I want to be sure before adding configuration
regards
most command syntax same and approach same.
Can you explain what is the goal here ? if one of the peer go other one automatically go as slave ? what you looking to achieve here ?
BB
the "interface" I want to track is my peering to the internet so if it goes down, I want to switch trafic (vip) to the second link
Nicolas
Sergiu.Daniluk
Do you have VPC configured? If yes, is the vlan 1145 allowed over peer-link? If also yes, then tracking is irrelevant, since FHRP in vPC setup, will always work in active/active (even if the status is active/standby).
Stay safe,
Sergiu
nop, no vpc on my side
Nicolas
