03-07-2023 05:45 AM
I have Nexus 3548 switch which is supposed to be 10GX version which is new one, which I can see in inventory but when do show version it doesn't show as GX version, is it because of old version??
AGG-MER-L3# show inventory
NAME: "Chassis", DESCR: "Nexus 3548 Chassis"
PID: N3K-C3548P-10GX , VID: V01 , SN:xxxxx
AGG-MER-L3# show version
Software
BIOS: version 2.0.6
loader: version N/A
kickstart: version 6.0(2)A6(5a)
system: version 6.0(2)A6(5a)
Power Sequencer Firmware:
Module 1: version v2.1
BIOS compile time: 12/26/2014
kickstart image file is: bootflash:///n3500-uk9-kickstart.6.0.2.A6.5a.bin
kickstart compile time: 2/13/2016 3:00:00 [02/13/2016 12:35:49]
system image file is: bootflash:///n3500-uk9.6.0.2.A6.5a.bin
system compile time: 2/13/2016 3:00:00 [02/13/2016 13:02:26]
Hardware
cisco Nexus 3548 Chassis ("48x10GE Supervisor")
Intel(R) Pentium(R) CPU @ 2.00GHz
with 3794024 kB of memory.
thanks
Solved! Go to Solution.
03-07-2023 06:10 AM
correct that can be different out puts in different versions.
03-07-2023 05:56 AM
thats normal. inventory shows exact model number. show version most of times shows series of device.
03-07-2023 06:02 AM - edited 03-07-2023 06:02 AM
ok thanks whilst on another box with later software version I can see the it correctly lists.
"cisco Nexus3500 C3548P-10GX Chassis"
Software
BIOS: version 5.4.1
NXOS: version 9.3(7)
BIOS compile time: 03/30/2020
NXOS image file is: bootflash:///n3500-compact.9.3.7.bin
NXOS compile time: 3/10/2021 3:00:00 [03/10/2021 13:39:29]
Hardware
Intel(R) Pentium(R) CPU @ 2.00GHz with 4029816 kB of memory.
Processor Board ID
03-07-2023 06:10 AM
03-07-2023 06:32 AM
there are four parts in NSK
SUP
Fabric
module
and Chassis
so you can see different part in each command
