POAP on n9kv on CML2?
machilde
Does anyone know if it is possible to run POAP in CML2?  It looks like a bootstrap file gets applied even if you clear out the config prior to booting.  Not sure if there is a way to skip this cdrom bootstrap?  Thanks in advance.
Trying to mount cdrom...
Mounted /dev/scd0 on /mnt/cdrom
Detected dynamic environment properties (bootstrap CLI) on nxos_config.txt
Copying nxos_config.txt ...
Applying bootstrap configuration...
Copy complete, now saving to disk (please wait)...
Copy complete.
[########################################] 100%
Copy complete.
kkhlebop
You should be able to POAP an N9Kv. You would need to run the appropriate services for the POAP server, either in a VM within the CML topology or externally bridged. Did you have any luck with that?
