MPLS
Hi dear community,I am facing an issue with the following setup :Ping is not OK for the BGP EVPN VPWS Service (Vlan / EVC 20).Here is the configuration of the involed PE :Cisco PE ISR1111:interface GigabitEthernet0/0/1 no ip address negotiation auto ...
Jerems by Spotlight
  • 9023 Views
  • 49 replies
  • 1 Helpful votes
In lab testing with MPLS-TE and SR-TE I see that with MPLS-TE policy and tunnel active, when SR-TE policy is configured, the route announced by SR-TE takes preference over MPLS-TE.Following is the output from MPLS-TE:RP/0/RP0/CPU0:pe2#sh route 10.0.0...
We have an MPLS L3VPN connectivity issue affecting one specific remote site. Topologi is below.AGDM has MP-BGP VPNv4 sessions with both XINDI ASR920 and 4YOL ASR920. The VRF is VOIP. AGDM has ibgp with MSE2 (AS34170).AGDM successfully learns the VOIP...
Hello, everyone.I'm studying MPLS for my CCNP exam. I understand that FEC is a group of packets that will be forwarded along the same path and will be treated the same way in terms of priority and treatment.I also understand that all packets that bel...
Mitrixsen by Spotlight
  • 238 Views
  • 0 replies
Hello,As my pre-final exam topic for CCNP SP, I’m currently studying MPLS and would like to ask a quick question. Is MPLS considered a tunneling protocol?I’ve always understood tunnels to have two key characteristics: encapsulation (for example, with...
  • 783 Views
  • 6 replies
Hello all, am trying to test MPLS VPNv4 feature on EVENG and my goal is to import default Internet route and MPLS VPNv4 with two different VRFS as mentioned below, Can someone guide me furhter to fix this issue. PE225-PE01#show running-config | sec v...
uni1389 by Level 3
  • 540 Views
  • 3 replies
Hi everyone, I am trying to configure ECMP for Segment Routing Traffic Engineering on an ASR920. Here is the configuration I have applied: segment-routing traffic-engsegment-list name SL_TEST_PATH_1index 10 mpls label 17201index 20 mpls label 15984 s...
config by Level 3
  • 1507 Views
  • 8 replies
I have Both NCS540 router and getting GTP loss on site, now i want to configure ECMP for load balancing, one media is MW and Secondary media is UBR so pls suggest how can i configure ECMP and how can i sure ECMP are working fine in router ?
soheljujara by Frequent Visitor
  • 298 Views
  • 0 replies
in IOS XE (and also XR if you want to), you need to use hex value to define affinity (admin group) for link colouring in RSVP-TE.since you can only configure one affinity per interface and one affinity/mask pair per LSP, does that mean the mask match...
daniel ng by Spotlight
  • 990 Views
  • 5 replies
I have a simple setup of a c3064X [nxos 7.0(3)I7(9)] connected to a NCS-5501 [XR 7.7.21] with a trunk using vlan 4048.  When I add the IP to the subif on the 5501 I can ping/connect both ways.  If I use a BVI [it is going to be a larger domain] it do...
lrgrnlife by Community Member
  • 1054 Views
  • 8 replies
Could you please tell me when will be the Cisco C1111-4P router be EoL?   Currently we have issues with some countries not letting the device to be installed and I would like to know if there will be an EoL announced in the next years.
in inter-AS VPN option C, we can use RRs of different ASes to peer with each other instead of PEs.when used in EVPN, IOS XE as RR must configure 'next-hop-unchanged' which makes it out of band or the forwarding will not work despite type 2 and 3 rout...
  • 574 Views
  • 0 replies
Unanswered Topics
Top Solution Authors
