Cloud Collaboration
Please note the Webex For Developers forum above has a more active community. Content will be migrating to this forum in the near future. For additional help, you can go to the Webex for Developers Support page.
The nbr2mp4 command line tool for Linux is available here: Utilities | WebExHowever it does not work properly after following the posted instructions. There is no support available through the traditional channels for this tool - one support tech tol...
Hopefully, the community can contribute to or use this program.Go-CDR (https://github.com/ZionDials/Go-CDR)Parses Cisco Collaboration Manager (CUCM/CCM) CDR/CMR files as well as Cisco UBE (CUBE) CDR files and inserts them into a database. Inserts CDR...
ziondials by Community Member
  • 1831 Views
  • 0 replies
  • 2 Helpful votes
It appears to me that there is no real security in Incoming Webhooks. I'd like to use it to send some alert messages from Azure/OpenShift etc. but it seems like the 'security' it uses is just a long hard to guess URL. There's no authentication per sa...
