12-01-2014 02:49 AM - edited 03-13-2019 08:45 PM
HAI
I WAS TRYING TO INSTALL ATA 190 ON CALL MANAGER 10.5
I HAVE INSTALLED DEVICE PACK AND RESTARTED BOTH SERVER,STILL THE NETWORK LED BLIKS FAST AND NO REGISTERING ,I TRIED MANUEL TOO ITS NOT SHOWING REGISTERED.
TFTP SHOWS ALL FILES AVAILABLE.
ATA 187 WAS HAVING NO ISSUES
ALL PHONE S ALL GOOD
PLEASE HELP
Solved! Go to Solution.
12-02-2014 08:31 PM
Hi Vijay,
Bug could be the issue
12-01-2014 06:47 AM
I had a similar problem installing the ATA 190 on CM 9.1.2.
A couple things that helped was loading the qed file on both Publisher and Subscriber. I also found that changing the data vlan on the switch port to one that is not assigning an IP address helps. It forces the ATA to get the IP from the Voice vlan and stay registered with that IP otherwise it kept trying to go thru DHCP process again and again. You may have to reset the ATA as well after that.
Even after I finally got them all registered to CM, they continue to randomly unregister. I'm actually reopening a TAC case today that addressed this.
Hope you have better luck.
12-01-2014 08:54 AM
Thanks for reply ,i face exact same issue,loading that files on tftp and restarting server i have done ,
I found ata not taking ip from voice vlan,also in web interface firmware is 004 ,there is an option to update firmware from file ,not through call manager,but in cisco site i dint see standalone file to update ata 190,you have any idea.Did yo upgrade firmware.
Please update me regarding solution from tac
12-02-2014 08:31 PM
Hi Vijay,
12-03-2014 07:22 AM
THANKS FOR REPLY
I WAS ABLE TO REGISTER ON CALL MANAGER, BUT FAXES OUT GOING INCOMING PROBLEM WITH THAT ATA 190.ATA 187 WORKING FINE.
I HAVE SINGLE SITE WITH SIP GATEWAY
ANYBODY PLEASE SEND GATEWAY AS WELL AS CONFIG ON ATA PAGE
ALSO ON WEB GUI I FOUND FIRMWARE UPDATE OPTION,BUT ANY STANDALONE FIRMWARE AVAILABLE TO UPDATE ,I COULDNT FIND AT CISCO SITE
05-27-2015 12:59 AM
ATA 190 is not getting registered with CUCM 10.5.
How to check ATA is having correct TFTP address or have received Config from CUCM?
Physically on ATA ,I have connected one analog phone, however i dont get Phone 1 , Phone 2 LED blinking .
07-10-2015 12:18 AM
I have the the same problem registering ata190 and ata187 to the cucm 9.1.2. Have install latest device pack "devicepack9.1.2_14094-1" and restarted the cluster, and still no luck.
FW on ata190 is ATA190.1-1-2-005 and on ata187 ATA187.9-2-3-1.
Any ideas?
07-21-2015 06:33 AM
Same Issue here with CUCM 10.5.2, also upgraded the ATA190 with the Last 1.2.1 004 of 17 July 2015.
Installed both QED and COP Files.
Any suggestion?
From TAC no Help
07-21-2015 06:57 AM
I've had a TAC case open since last October. We've updated QED and COP files several times, still not resolved. Hanging onto my 186 and 187s hoping they don't die.
07-21-2015 07:22 AM
07-24-2015 02:48 AM
Hi guys,
i'm experience the same problem in CUCM 10.5 , and my ATA 190 has already the last firmware :
Firmware Version: | 1.2.1 (004) Jun 5 2015 |
Any more ideas about this problem?
Best Regards
07-24-2015 06:35 AM
Did you leave blank the Display Caller ID relative to the device?
Did still not work?
07-24-2015 07:07 AM
Yes , i tried it.
I still tried to create the device without any line and still, nothing.
Thanks.
07-24-2015 07:35 AM
07-24-2015 07:41 AM
Ok, i understand , and my line is without any description.
Regards.
