12-01-2014 02:49 AM - edited 03-13-2019 08:45 PM
HAI
I WAS TRYING TO INSTALL ATA 190 ON CALL MANAGER 10.5
I HAVE INSTALLED DEVICE PACK AND RESTARTED BOTH SERVER,STILL THE NETWORK LED BLIKS FAST AND NO REGISTERING ,I TRIED MANUEL TOO ITS NOT SHOWING REGISTERED.
TFTP SHOWS ALL FILES AVAILABLE.
ATA 187 WAS HAVING NO ISSUES
ALL PHONE S ALL GOOD
PLEASE HELP
Solved! Go to Solution.
07-24-2015 08:52 AM
Your CUCM Cluster is Mixed Mode or Unsecure?
Did you try to register the ATA190 using Autoregistration?
07-24-2015 08:54 AM
-Unsecure mode
-With Autoregistration is the same problem . i always got " Rejected" in phones page.
07-24-2015 08:58 AM
Cisco TFTP service restarted?
Factory default of the ATA190 done?
Try a brand new one ATA190?
08-11-2016 04:48 AM
07-23-2015 05:16 AM
Hi All
This is resolved for me. As per TAC suggestion , I upgraded ATA with IMAGE file " ATA190.1-1-2-005.primary" .
Upgrade option available on WebGUI of ATA.
Connect to TAC for image file.
SANKET G
08-20-2015 07:18 AM
Do you have a link to download "ATA190.1-1-2-005.primary"? I'm getting not found on the support site.
08-14-2019 01:19 AM
01-06-2015 07:49 AM
I know this has already been answered a few weeks ago but just fyi... TAC issued me a new firmware 1.1.1-03
We'll see if it resolves the problem.
01-06-2015 09:30 AM
Please do update on the results.
regds,
aman
03-13-2016 12:12 AM
For ATA 190 you need a cluster restart after installing new firmware..
09-18-2020 06:16 AM
I had this same issue and it turned out to be the TFTP service was not running!
