09-10-2002 07:40 AM - edited 03-12-2019 08:42 PM
I'm just starting to test out Attendant Console and am finding that if I try to look up a whole department at a time that I only get 10 people, but if I look up All, then everyone is there. Any idea why?
09-18-2002 06:06 AM
Beter check with Cisco. It should all show up in directory view.
09-18-2002 09:38 AM
Make sure you have department field populated in the User configuration screen.
When you show all users ..are there more users than 10 that have Department field populated ?
-Amisha
09-18-2002 09:42 AM
Yes, the department fields are populated and I do show more than 10 when showing all users.
09-19-2002 05:12 AM
Hope this helps:
The attendant console server reads and caches directory entries at startup; after an initial handshake determines if the directory entries changed since the previous log in, the attendant console downloads the directory user list. The attendant console searches the following files for the user list, as indicated in the following order:
Specified user list file on the attendant console configuration
CorporateDirectory.txt file under the User List Directory on the server
Automatically generated (When TCD service starts) user list file on the server
The user list file exists in comma separate value (CSV) format and contains the following information:
Last Name
First Name
Telephone Number
Department
Note Directory entries without telephone numbers do not display in the attendant console Directory window.
The attendant console server also stores per-attendant information such as speed-dial groups/entries and window positions in the directory, which ensures that each attendant can see the saved information and GUI layout from any attendant console.
