call summary report extension by extension in car
Cisco CDR Analysis and Reporting allow you to extract calls by directory number within System Reports / Traffic / Summary By Phone Number. The problem is that if you add several extensions the result is the sum of the calls and I need calls of each extension.
Is there any way to show the total calls of each directory number without having to go one to one?
Thank you!
Manish Gogna
Hi Alvaro,
You may try the CDR > Search > By  User / Phone Number / SIP URL
Manish
Kay Tobin
The Enterprise Overview Report on either our TIM Plus or TIM Enterprise product would show you this. You can download a free trial if you want to play with it. If logging less than 400 directory numbers, try TIM Plus, if more than that try TIM Enterprise. http://www.tri-line.com/cisco/
