Cisco Voice Gateway PRI and Nortel 81c
a.contento
Has anyone used PRI-NI2 between the an Option81c and a Cisco GW? I have seen examples on CCO that use 5ESS successfully, but not NI2.
mimckee
We ususaly do dms-100 between nortel and cisco gw. I have heard there are issue with using ni2. That was in the past I am not sure if it is still a problem. If you are using IOS gateway then make the nortel network side sl100 and cisco user side dms-100. If you are using 6608 or dt-24+ I think we can just be network side dms-100 and nortel be user side.
Hope this helps,
-Mckee
wes_ward
Here are all of my Nortel 81C configs for DMS100.
****Special Notes
FNP = Flexible Numbering Plan must be YES or 000 is
added to the number field when calling Meridian to AVVID.
TRNX = Transfer on Private Network Must be YES or will not be able to transfer calls.
EXTT = External Trunk to Trunk Must be YES or will not be able to transfer calls.
LD 15
TYPE NET_DATA
CUST 00
OPT RTD
AC2
FNP YES
ISDN YES
PINX_DN
HNPA 920
HNXX 734
HLOC
LSC
RCNT 5
OCLI NO
TRNX YES
EXTT YES
FTOP FRES
VNR NO
NIT 8
FOPT 14
****Special Notes
TKTP = TIE
DDMI = Digit Manipulation Index Does not need to be set unless you want it set here.
IFC = S100
Cisco Router should be DMS100 (This is how name/number passes).
NCNA = YES Network Calling Name Allowed
NCRD = YES Network Call Redirection Allowed
IANC = YES or NO Depending on configuration.
LD 16
TYPE RDB
CUST 00
ROUT 82
DES AVVID2
TKTP TIE
NPID_TBL_NUM 0
ESN YES
CNVT YES
DDMI 9
ATDN 2400
SAT NO
RCLS INT
DTRK YES
DGTP PRI
ISDN YES
MODE PRA
IFC S100
SBN NO
NCNA YES
NCRD YES
CHTY BCH
CTYP CDP
INAC YES
ISAR NO
CPUB OFF
DAPC YES
TBL 0
BCOT 0
DSEL 3VCE
PTYP PRI
AUTO NO
DNIS NO
DCDR NO
ICOG IAO
SRCH LIN
TRMB YES
STEP
ACOD 6672
TCPP NO
TARG 01
CLEN 1
BILN NO
OABS
INST
IDC NO
DCNO 0 *
NDNO 0
DEXT NO
ANTK
SIGO STD
ICIS YES
TIMR ICF 512
OGF 512
EOD 13952
NRD 10112
DDL 70
ODT 4096
RGV 640
GRD 896
SFB 3
NBS 2048
NBL 4096
TFD 0
PAGE 002
DRNG NO
CDR NO
MUS YES
MRT 47
RACD NO
EQAR NO
FRL 0 0
FRL 1 0
FRL 2 0
FRL 3 0
FRL 4 0
FRL 5 0
FRL 6 0
FRL 7 0
OHQ NO
OHQT 00
CBQ NO
AUTH NO
PLEV 2
ALRM NO
ART 0
SGRP 0
AACR NO
****No Special Notes Here
LD 14
TN 094 01
TYPE TIE
CDEN SD
CUST 0
TRK PRI
PDCA 1
PCML MU
NCOS 7
RTMB 82 1
B-CHANNEL SIGNALING
TGAR 0
AST NO
IAPG 0
CLS UNR DTN CND WTA LPR APN THFD HKD
P10 VNL
TKID
DATE 12 DEC 2001
****Special Notes
IFC = S100
RCAP = ND2 (Name Display Method 2) So name comes across.
SIDE = NET Must be Network because Cisco usually configs their side as USER.
LD 17
ADAN DCH 9
CTYP MSDL
GRP 2
DNUM 7
PORT 2
DES avvid
USR PRI
DCHL 94
OTBF 32
PARM RS422 DTE
DRAT 64KC
CLOK EXT
IFC S100
SIDE NET
CNEG 1
RLS ID **
RCAP ND2
T200 3
T203 10
N200 3
N201 260
K 7
LD 20
TYPE TLST
TKTP TIE
ROUT 82
DES AVVID2
TN 094 01 MBER 1 AVVID
TN 094 02 MBER 2 AVVID
TN 094 03 MBER 3 AVVID
TN 094 04 MBER 4 AVVID
TN 094 05 MBER 5 AVVID
TN 094 06 MBER 6 AVVID
TN 094 07 MBER 7 AVVID
TN 094 08 MBER 8 AVVID
TN 094 09 MBER 9 AVVID
TN 094 10 MBER 10 AVVID
TN 094 11 MBER 11 AVVID
TN 094 12 MBER 12 AVVID
TN 094 13 MBER 13 AVVID
TN 094 14 MBER 14 AVVID
TN 094 15 MBER 15 AVVID
TN 094 16 MBER 16 AVVID
TN 094 17 MBER 17 AVVID
TN 094 18 MBER 18 AVVID
TN 094 19 MBER 19 AVVID
TN 094 20 MBER 20 AVVID
TN 094 21 MBER 21 AVVID
TN 094 22 MBER 22 AVVID
TN 094 23 MBER 23 AVVID
LD 86
RLI 52
ENTR 0
LTER NO
ROUT 82
TOD 0 ON 1 ON 2 ON 3 ON
4 ON 5 ON 6 ON 7 ON
CNV NO
EXP NO
FRL 0
DMI 0
FCI 0
FSNI 0
SBOC NRR
OHQ NO
CBQ NO
ISET 0
NALT 5
MFRL 0
LD 87
DSC
DSC 2424
FLEN 4
DSP LSC
RLI 52
NPA
NXX
DSC 2499
FLEN 4
DSP LSC
RLI 52
NPA
NXX
Procedures for Setting Up an IP Phone for an Existing PBX Extension
Steps
#1. Log in to the PBX, then Print the DN you want to be an IP Phone DN in LD 20.
>ld 20
PT0000
REQ: prt
TYPE: dn
TYPE DNB
CUST 0
DN 2400
DATE
PAGE
DES
DN 2400
TYPE SL1
TN 116 0 15 04 KEY 00 H MARP DES L4DI03 27 JAN 2002
(3904)
NACT
#2. Remove the DN from every phone it appears on.
REQ: chg
TYPE: 3904
TN 116 0 15 4
ECHG yes
ITEM key 0 nul
KEY
ITEM
HNT FNA
HNT FNA
HNT FNA
#3. Add the DN in LD 87 to the Coordinated Dial Plan as a Distant Steering Code in RLI 52. Flen must be 4 unless the extension has more than 4 digits.
>ld 87
ESN000
MEM AVAIL: (U/P): 4154561 USED U P: 2801757 498401 TOT: 7454719
DISK SPACE NEEDED: 816 KBYTES
2MB BACKUP DISKETTE(S) NEEDED: 1 (PROJECTED LD43 - BKO)
REQ new
CUST 0
FEAT cdp
TYPE dsc
DSC 2400
FLEN 4
DSP
RLI 52
NPA
NXX
DSC (enter again if there are no more DNs to enter)
VG200 Router Config for DMS100
aalcmvg001#sh run
Building configuration...
Current configuration : 1570 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname aalcmvg001
logging buffered 4096 debugging
enable password avvid
voice-card 1
ip subnet-zero
call rsvp-sync
isdn switch-type primary-dms100
voice rtp send-recv
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface FastEthernet0/0
ip address 10.80.231.41 255.255.255.0
speed 100
full-duplex
interface Serial1/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
isdn map address ^[1-9] plan unknown type unknown
isdn map address ^011 plan unknown type unknown
isdn flip-chan-flag
isdn T310 30000
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.80.231.1
no ip http server
ip pim bidir-enable
voice-port 1/0:23
input gain -1
output attenuation 1
echo-cancel coverage 32
no comfort-noise
dial-peer voice 9 pots
destination-pattern 9
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 1/0:23
dial-peer voice 1 voip
preference 10
destination-pattern .T
progress_ind setup enable 3
session target ipv4:10.80.231.31
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2000 voip
destination-pattern 2...
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
codec g711ulaw
no vad
line con 0
line aux 0
line vty 0 4
password avvid
login
end
aalcmvg001#
dgahm
Level 8
Level 8
Yes, I am running PRI-NI2 between a 81C and a 3640 GW running MGCP with backhaul. Works fine, no issues yet, but have only had it set up in a lab environment for a few days.
