05-08-2006 05:10 AM - edited 03-15-2019 04:20 AM
Is there any way in which Speed Dials can be imported for all lines on all Device User Profiles via BAT?
I have a number of User Device Profiles, each having one line allocated. I would like to allocate the same Speed Dial set of numbers to all lines. Can I use BAT for this, or is there another way?
Thanks. Barry
05-08-2006 05:23 AM
Hi, you have two choices:
1- BAT: Export all your profiles, delete the existing then import all. change your Speed Dials using Excel. You may need a BARS backup in case somethings goes wrong when you delete and then import. Restoring with BARS is easy.
2- If 1 is too complicated just give your Users the http://CCMadress/ccmuser its much better so they can customise theire Phones.
Karzazi
Please rate if helpful.
05-08-2006 09:55 AM
Thanks for the response - I'd kind of worked out that the Delete / Reimport using BAT was the only way this was going to work. A little bit unfriendly I must say (and yes, BARS has been my saviour on more than one occasion!). I have 30 speed dials to add, so it would have been much easier if there was simply an update option available to do it.
Thanks. Barry
05-08-2006 01:44 PM
it could be done via AXL
