Cracking Noise on ISDN Line BRI
fimozo
We have a CUCM that is using a cisco router gateway with the ISDN VWIC cards. We have this consistent cracking sound on calls. if call are made direct from the modems this sound is not there meaning the issue is on the router. anyone please advise.
Can you share the show controller E1/T1 output ?
Response Signature
thanks for the response
its a bri not pri so cannot show that command
Try a different line card and see it makes any difference.
Response Signature
Scott Leport
Level 7
Level 7
Not worked with BRI for a while, but issue sounded vaguely familiar.
Can you check if the following commands are applied to your voice-port? If not, can you try them?
bearer-cap speech
compand-type ulaw
