CUE and IVR options
yosoypako
Hello.
Our customer wants to route the incoming calls to a CUE. Once the call arrives to the CUE they want to play a different prompt and route the call to a different directory number depending on the incoming calling number pattern. If the incoming calling number begins with a 8 or 9 play a prompt and transfer the call to a destination dn, if the incoming calling number begins with 3 to play another different prompt and tranfer to another destination number.
We have included these licenses in the CUE:
FL-CUE-IVR-2 -->Unity Express License - 2 IVR Session
Are we going to be able to use the "Get Call Contact Info" and the "if" steps to do this?
Manish Gogna
You should be able to use them, please follow the CUE Script Editor Step Reference guide for the same
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel7_0/administrator/script/scripteditor/stpref.html#wp1001223
Manish
- Do rate helpful posts -
Manish Gogna
Manish
Thanks Manish.
In the if step, can we use boolean expressions like "incomingcall = 91*******" to match any incoming call number from 910000001 to 919999999?
While the wildcard patterns are supported for both SIP and JTAPI triggers, i am not sure about getting this to work within the 'If' step. If you have the lab already setup for the same you may try setting up a basic script to test this first.
Manish
Hello.
I do not have the lab enviroment yet. Has anybody made this kind of script configuration or can test it?
Thanks for your help.
