Expansion Module screen too dark?
wain_ip
Has anyone used expansion module? I have tried this product recently, everything works fine except the screen. I think the screen is too dark to see the speed dial on it. I have tried both 7914 and 7915, but got same result. How can tune it more easy to see? Thank you!
Jonathan Schulenberg
You can use the Contrast setting in the phone's settings button. The 7914 and 7915 are monochrome without backlighting so be sure you are not expecting something it does not provide.
Thanks for your help, it works fine!!!
Thanks for your help. The 7915 works fine now
Thanks Jonathan.  Saved me a little research in the field just now!
