06-23-2006 11:29 AM - edited 03-15-2019 04:23 AM
Hi all,
I have a new 2851 running 12.3911)T10
1 MFT T1 in the MBRD slot 3
CM 4.1.2 with a publisher and sub
P 10.1.8.16
S 10.1.8.15
I will past the config in here, but here is the issue, the Sub as the Primary will not register even though the Pub is fine. (see "sh ccm" output) I have verified:
--network connectivity
--DNS name and gateway name in CM and router both include "spps.com"
--stipped and re-applied "mgcp" global command
--ran DB Helper to make sure database was replicating
I am all out of ideas on this.
help
sh ccm:
VR01-1930#sh ccm
MGCP Domain Name: VR01-1930.spps.org
Priority Status Host
Primary Down 10.1.8.15
First Backup Registered 10.1.8.16
Second Backup None
Current active Call Manager: 10.1.8.16
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 14:27:55 DST Jun 23 2006 (elapsed time: 00:00:10)
Last MGCP traffic time: 14:27:55 DST Jun 23 2006 (elapsed time: 00:00:10)
Last failover time: 13:40:55 DST Jun 23 2006 from (10.1.8.15)
Last switchback time: 12:19:15 DST Jun 23 2006 from (10.1.8.16)
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
--More-- Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 10.1.8.16
Current Link State: OPEN
Statistics:
Packets recvd: 0
Recv failures: 0
Packets xmitted: 0
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, port 0
Configuration Error History:
FAX mode: disable
VR01-1930#
SH run vitals:
sh run
Building configuration...
Current configuration : 2487 bytes
version 12.3
hostname VR01-1930
ip domain name spps.org
no ftp-server write-enable
isdn switch-type primary-ni
voice-card 0
no dspfarm
ccm-manager redundant-host 10.1.8.16
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.1.8.15
controller T1 0/3/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
description 1930 Como PRI
interface GigabitEthernet0/0
description Connection to VOICE NET on 1930-Como Switch
ip address 10.1.8.10 255.255.254.0
duplex full
speed 100
interface Serial0/3/0:23
no ip address
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.8.1
voice-port 0/3/0:23
mgcp
mgcp call-agent 10.1.8.15 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
VR01-1930#
06-23-2006 01:14 PM
hi,
As mentioned that network connectivity is fine.What abt the phones do the they get registered to PUB.Can you make calls between phones which are connected to seperate CCM.
Can you verfiy the version of softwares running on both the servers.
