08-16-2012 03:52 AM - edited 03-03-2019 06:43 AM
HI , can anyone tell how many Gigabit port will be supported by Cisco 7206VXR with G1 engine model. By deault we hot 3 GE, is it possible to add additional Gigabit ports with the existing hardware. Please clarify.
08-16-2012 06:54 AM
You can add a PA-GE, but it will not have good performances like the embedded itnerfaces, so it's not advisable to do that.
08-17-2012 01:57 AM
Hi paolo, thanks for the reply, I need some more clarification, Apart from 3 embeded GE ports, how many we can add if we want. In case if we add how it will degrade the performance or any cause bcz of that.
08-17-2012 08:00 AM
You will need to work through the details based on bandwidth
see the link below.:
If you need that much gigabit, I would suggest a better router.Based on my own experience effective throughput on a Gig interface tops out around 800Mb.
