Bookmark
Subscribe
1350
Try to configure NM-8AM module to act as RAS in 2620 router
rhollen
Replacing and old RAS box with a 2620 router and NM-8AM module solution. I have followed the sample configuration at http://www.cisco.com/en/US/products/hw/modules/ps2797/products_configuration_example09186a00800e0dcd.shtml, but when trying to test with one phone line into any of the 8 ports, it just rings; the modem never picks up. I know the line is active, I can connect to an external modem on the AUX port just fine. Beginning to think the module is bad?
Specs:
2620 with 12.2(2)T with IP/IPX/AT/DEC
NM-8AM with Modem Firmware Version 1.2.8
Any help is appreciated.
TIA
Robb
17 Replies 17
zahmed
Could you post the portions of config from group-async interface and the tty/modem lines ?
~Zulfi
I'll just post the whole thing omitting passwords, etc.
Current configuration : 1621 bytes
! NVRAM config last updated at 21:38:48 UTC Mon Mar 31 2003
version 12.2
no parser cache
no service single-slot-reload-enable
service timestamps debug datetime localtime
service timestamps log datetime localtime
hostname TippCityRAS
logging rate-limit console 10 except errors
enable secret 5 ***
username rhollen nopassword
ip subnet-zero
ip domain-list ***.com
no ip domain-lookup
ip domain-name ***.com
no ip dhcp-client network-discovery
async-bootp dns-server ***
interface FastEthernet0/0
ip address ***
speed 100
full-duplex
no cdp enable
interface Group-Async1
no ip address
encapsulation ppp
dialer in-band
dialer idle-timeout 3600
dialer-group 1
async mode interactive
peer default ip address pool dialin
ppp authentication chap
group-range 33 40
router eigrp 1
network ***
auto-summary
no eigrp log-neighbor-changes
ip local pool dialin ***
ip classless
ip route 0.0.0.0 0.0.0.0 ***
ip http server
dialer-list 1 protocol ip permit
no cdp run
line con 0
exec-timeout 0 0
password ***
login
line 33 40
modem InOut
transport input all
autoselect ppp
flowcontrol hardware
line aux 0
password ***
login
modem InOut
modem autoconfigure type usr_courier
transport input all
speed 115200
line vty 0 4
exec-timeout 5 0
password ***
login
line vty 5 15
exec-timeout 5 0
password ***
login
no scheduler allocate
ntp clock-period 17179870
ntp server ***
end
TippCityRAS#
Config looks good...can you please try the reverse telnet test.
With reverse telnetted into the modem, try & make a call into the same modem, do we see a incomming RING?
Thanks, Mak.
makchitale
Level 6
Level 6
Can we reverse telnet into the modems? Can we make a successful call OUT by reverse telnetting into any internal modem using ATDT?
telnet <2000+line#>
eg: telnet 1.1.1.1 2033
then, ATDTxxxxxxxxx
Thanks, Mak.
Had to add loopback0 to configuration I posted. Phone line is on port 0 of nm-8am module:
TippCityRAS#telnet 1.1.1.1 2033
Trying 1.1.1.1, 2033 ... Open
at
OK
at&f
OK
TippCityRAS#disconnect
Closing connection to 1.1.1.1 [confirm]
TippCityRAS#
I don't know other AT commands to try.
Robb
you dont have an IP addr on the group async. I believe it must be failing in IPCP portion , making you think modem is not picking up. Try that please.
~Zulfi
Just try calling a phone number located near you (or your cell phone#) & see if it rings,
AT
OK
ATDT1408xxxyyyy
If that works, then remain in the reverse telnet session & call into the same modem to see incomming RING.
just adding further to Zulfi's note, add "ip unnumbered loopback0" under interface group-asy 1.
Thanks, Mak.
Yes, I added the following to the config after I posted it when mak asked me to reverse telnet to the modems:
interface Loopback0
ip address 1.1.1.1 255.255.255.0
int group-async1
ip unnumbered Loopback0
So with the phone line plugged into modem port 0 on the nm-8am, I did a reverse telnet to all eight modems and tried to call my cell phone:
at
OK
atdt19378770912
NO DIALTONE
TippCityRAS#telnet 1.1.1.1 2034
Trying 1.1.1.1, 2034 ... Open
at
OK
atdt19378770912
NO DIALTONE
TippCityRAS#telnet 1.1.1.1 2035
Trying 1.1.1.1, 2035 ... Open
at
OK
atdt19378770912
NO DIALTONE
TippCityRAS#telnet 1.1.1.1 2036
Trying 1.1.1.1, 2036 ... Open
at
OK
atdt19378770912
NO DIALTONE
TippCityRAS#telnet 1.1.1.1 2037
Trying 1.1.1.1, 2037 ... Open
at
OK
atdt19378770912
NO DIALTONE
TippCityRAS#telnet 1.1.1.1 2038
Trying 1.1.1.1, 2038 ... Open
at
OK
atdt19378770912
NO DIALTONE
TippCityRAS#telnet 1.1.1.1 2039
Trying 1.1.1.1, 2039 ... Open
at
OK
atdt19378770912
NO DIALTONE
TippCityRAS#telnet 1.1.1.1 2040
Trying 1.1.1.1, 2040 ... Open
at
OK
atdt19378770912
NO DIALTONE
TippCityRAS#
When I plug the line into a phone, I get a dialtone and can send and receive calls on it. I'm stumped.
Robb
Looks to me a faulty NM-8AM card here....also since this is a 2620 there is no way we can try this in another slot of the chassis (maybe we can try it in another chassis)
Thanks, Mak.
I'll try another chassis before I look into replacing the module.
Thanks for your help thus far.
Robb
Hi, as what Mak has mentioned, it looks like you do have a faulty module. You might also want to check for proper grounding if you haven't done so, but this should not be directly related to the problem. Although the grounding issue is usually related to poor or unsuccessful connections, it is worth a try. Just a wild guess. Thanks.
OK, I have replaced the module. I can reverse telnet to modem0 (2033) and call my cell phone and it rings. But when I try to call in to the number it still just rings and rings. I think I'm missing something obvious here. I'm posting my configuration again, just to make sure I'm not missing anything.
TippCityRAS#sh run
Building configuration...
Current configuration : 1431 bytes
! No configuration change since last restart
version 12.2
no parser cache
service timestamps debug uptime
service timestamps log uptime
enable secret 5 ***
username *** nopassword
ip subnet-zero
no ip domain-lookup
ip domain-name ***
interface Loopback0
ip address ***
speed 100
full-duplex
encapsulation ppp
dialer in-band
dialer-group 1
group-range 33 40
router eigrp 1
network ***
auto-summary
ip classless
ip http server
line con 0
exec-timeout 0 0
password ***
login
line 33 40
modem InOut
transport input all
autoselect ppp
line aux 0
line vty 0 4
password ***
login
line vty 5 15
login
ntp clock-period 17179925
ntp server ***
end
TippCityRAS#
Any ideas?
Robb
The config looks good, can you please try adding the following after reverse telnetting into the modem: AT&Fs0=1
It will be interseting to see if any of these two cards work fine in another chassis, could be a chassis problem too. Also as Ariel mentioned, ensure that the 2600 chassis is properly grounded.
Thanks, Mak.
OK, I've determined modem0 and modem4 are not working inbound, only outbound. The rest are working both ways. So I need to get another replacement module (that's what I get for buying used, at least they're under warranty). I have a few more questions:
1. I cannot seem to use the nopassword command. How do you setup not to use a password? If I do the 'username xxx password 0 xxx' command I connect fine, but 'username xxx nopassword' does not connect.
2. I need IPX capabilities as well. Do I just need to add a 'dialer-list 1 protocol ipx permit' command?
Thanks for all your help Mak.
Robb
