AP Unable to Join Controller - Invalid License in configuration request
jasonrule
I have installed a new second WLC 2500.  In an attempt to join an AP 2700 to the new WLC I configured the primary controller in Wireless > [The AP] > High Availability tab.  After doing this the AP lost connection to both the new and old WLC.  I then did a factory reset using the Mode button.  Now the AP cannot join the controller.  I keep getting the Invalid License in configuration request error.  I have reset the AP to factory settings multiple times but cannot get it to join the WLC.  I have searched and searched for a solution but cannot find one.  Please help!
That is your problem. I'm pretty sure the 2700 AP is supported starting 8.0 or even 8.1.
So yeah, upgrade both of them to the current stake release 8.2.170.0 (check the release notes if all your AP models are supported by it).
26 Replies 26
Pls post "show sysinfo" from your WLC & "show ver" from your AP
Rasika
Hello, here is the output from the show commands. Thank you.
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.1.102.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... GT WLAN
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.5.1.68
IPv6 Address..................................... ::
Last Reset....................................... Power on reset
System Up Time................................... 115 days 0 hrs 26 mins 38 secs
System Timezone Location......................... (GMT -6:00) Central Time (US and Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +33 C
External Temperature............................. +37 C
Fan Status....................................... 3500 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 70
Burned-in MAC Address............................ 38:ED:18:50:5D:E0
Maximum number of APs supported.................. 75
System Nas-Id.................................... GT WLAN
WLC MIC Certificate Types........................ SHA1/SHA2
AP0462.7337.f6cc>show ver
Cisco IOS Software, C2700 Software (AP3G2-K9W8-M), Version 15.3(3)JBB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 04-May-15 17:26 by prod_rel_team
ROM: Bootstrap program is C2700 boot loader
BOOTLDR: C2700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB5m, RELEASE SOFTWARE (fc2)
AP0462.7337.f6cc uptime is 7 minutes
System image file is "flash:/ap3g2-k9w8-mx.153-3.JBB/ap3g2-k9w8-xx.153-3.JBB"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP2702I-UXK9 (PowerPC) processor (revision A0) with 376810K/134656K bytes of memory.
Processor board ID FCW1938P0YX
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.1.102.0
Access Point Type: World Mode
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 04:62:73:37:F6:CC
Part Number : 73-15824-03
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC19383070
Top Assembly Part Number : 068-100395-01
Top Assembly Serial Number : FCW1938P0YX
Top Revision Number : A0
Product/Model Number : AIR-AP2702I-UXK9
Configuration register is 0xF
I would upgrade WLC software first as 8.1.102.0 is not a recommended version. Go with either 8.2.170.0 or 8.5.140.0 (remember 8.5.x is the last supported code version for 2504/5508/WiSM2). Please check below compatibility matrix & see all your AP model is supported by code version you go with.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#56735
Then I would plug that 2702 on a switchport configured on same vlan as WLC management vlan, in that way it will discover WLC via broadcast & should able to register. If you see same issue, pls attache AP console output as txt file to see exact error message.
Rasika
*** Pls rate all useful responses ***
ammahend
also paste show license all from both WLCs
-hope this helps-
How do you get the license information?
Is it the information under Management > Software Activation > Licenses in the GUI?
If there is an CLI command, can you tell me what it is?
Thank you.
show license all
Now I am getting a new error:
Discarding LWAPP Discovery Request from AP Since entry exists in CAPWAP.
Is there a way to clear this?
Here is the license information from the controller on the 10.5.1.x subnet
(Cisco Controller) >show license all
License Store: Primary License Storage
StoreIndex: 0 Feature: base Version: 1.0
License Type: Permanent
License State: Active, Not in Use
License Count: Non-Counted
License Priority: Medium
StoreIndex: 1 Feature: base-ap-count Version: 1.0
License State: Active, In Use
License Count: 25 /25 (Active/In-use)
License Store: Evaluation License Storage
StoreIndex: 0 Feature: base-ap-count Version: 1.0
License Type: Evaluation
License State: Inactive
Evaluation total period: 12 weeks 6 days
Evaluation period left: 12 weeks 6 days
License Count: 75 / 0 (Active/In-use)
License Priority: None
Here is the license information from the WLC on the 10.70.1.x network
How many APs currently registered to your WLC ? Below indicate all 25 licenses are in use ? This could be the reason why your AP is not registering.
Rasika
There are currently 19 Aps joined to the 10.5.1.x WLC and no Aps joined to the 10.70.1.x WLC.
We only have a total of 21 APs.
Does 10.70.1.x network is DHCP enabled ? if that is the case I would put new AP on that vlan & see what's happen.
Pls post "show sysinfo" output from that WLC as well.
Rasika
When I try to connect to the 10.70.1.x WLC it tries but fails to connect. The message in the WLC GUI under Monitor > Statistics > AP Join is:
Last AP Disconnect Reason: Unknown failure reason
Please disregard last post.  That was a different AP.
I get a different error for WLC 10.70.1.x as I do on WLC 10.5.1.x.
The error on 10.70.1.x is: Regulatory domain in configuration request is invalid
I continue to try to connect the APs.  Maybe some progress?  I am now getting a new error:
