04-26-2010 03:10 PM
My question is about motion recording. When the system is configured to record by motion it looks like it does so in 1 hour loops – how can you change that or access/search archives older than one hour?
04-27-2010 12:39 PM
sounds like you are running VSOM/VSMS version 4.2/6.2.
If you want to use motion configs you have some work to do. You have to set up events to trigger on motion, define the motion area, set up specific archiving to save that motion and how long you want to retain the archive.
Its easier than it sounds but you cannot just click the motion box in batch admin and have it magically work. Sorry. I wish it worked like that.
08-18-2010 02:13 AM
I am facing a similar problem , i want it to record based on motion , created an event ,selected the archive and made schedule but it is still recording all the time
Any advise
08-18-2010 06:13 PM
VSOM will record all video until the system starts to run low on disk space it will then delete video that is not tagged as motion.
09-28-2010 01:50 AM
Try disabling the event.
No logic here from Cisco but this works.
Pieter
12-16-2010 09:58 AM
Any resolution on this?
Event is setup
Schedule is set (Recurring)
Archives/Clips are set
Still it detects and records events outside of the scheduled time.
12-16-2010 06:04 PM
Yeah,
The last I did it was on Vsom 6.2. Configured the event, then disabled it to complete the configuration, then lastly enabled it whcih seemed to work.
We found any version prior 6.2 was waste of time with motion recording.
Good luck
12-17-2010 09:24 AM
Thanks for the reply. Yeah, this is driving me crazy. I can kind of get it working but then it doesn't function properly...
I'll post here if I find any solutions.
01-02-2011 11:18 AM
Hi ,
I have a problem concerning motion recording .
I created an event , window of motion with highest sensitivity , select an archive for recording
but some motions aren't recorded ( I'm using VSOM 6.3.0 , Camera Firmware 2.1.2 )
Any advise ?
01-03-2011 02:21 PM
I found that it depends on how long you want each event to be recorded. So if you trigger an event at 12:00, and
motion detected is set to record for 30 secs after the event, an event at 12:00:
15 will not trigger as a motion. Besides that, we found the motion detection to be pretty good from Ver 6.2.
01-03-2011 08:36 PM
Motion Detection is set to record 5 sec. after the event and also some motions aren't recorded
02-04-2011 05:02 PM
Hey Chris, how'z it going? =) Cisco still has not written the correct procedure in the VSG 6.3.1 User's Guide for Motion-Only recording, but there are ways in unreleased documents to do this, if you wanted to know for non-IFS reasons then email me for the "undocumented ways" and i'll supply them, otherwise we're good on this over at IFS. Cheers.
02-07-2011 11:35 AM
Hi Chris,
Have you been able to achieve your desired result?
If you are seeing a 1 hour loop for the feed, then it sounds like you have an archive configured for this feed as a 1 hour loop. If you only want to record motion events, then you don't need to configure an archive at all for the feed.
Please mark the question as answered if anyone has answered it for you. Otherwise, please give us an update and let us know if we can help.
Sean
02-08-2011 05:07 PM
I hope Cisco will publish a configuration guide for motion configuration and other complex configuration. Hopefully, with screenshots as well because the help functions on the VSM is not that helpful sometimes.
02-08-2011 08:18 PM
Yes, Cisco needs to define the differences, like Scheduled MotionDetection-Only Recording&Archiving verses MotionDetectionEvent Archiving in Loops. It can get confusing trying to get these setup using the VSM UG, so i look forward to the 6.3.2 VSM UG.
