06-13-2013 10:21 PM
I'd like to know what type of VPN throughput I should be seeing for the rv016 connected via a site-to-site vpn. One of my connections has a t1 while the other has 4mbps upload bandwidth. I know that would translate to roughly 100k/sec and 400k/sec, but I don't think I'm seeing anything near that.
Any opinions and experiences appreciated.
<p/><p/><p/>Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
06-14-2013 02:28 PM
Dear Samir,
Thank you for reaching Cisco Small Business Support Community.
Please find below a IxChariot performance test on a RV042 for your reference;
The test summary in Mbps:
RV016 | WAN - LAN 94 | LAN - WAN 94 | Simultaneous 156 | client to gateway (3DES, MD5) 71 |
I hope you find this information helpful and please let me know if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
06-14-2013 04:25 PM
Thank you for the quick reply, but I believe this is for v3 hardware. I want to know what the earlier models are supposed to be capable of. Do you have anything for v1 hardware?
06-17-2013 09:21 AM
Hello Samir,
Unfortunately I have found no related documentation on the version 1 of the RV016 router, neither I can run the test since I have no access to one. I suggest you to contact the Small Business Support Center to find out if they can provide you the requested info;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach me back if there is any further assistance we may help you with.
Thanks again,
07-08-2013 11:06 PM
I'm about to get rid of my rv016 v1 because I need something that will do wire speed. If you can create any test data for the v1 hardware, I will keep these in service.
07-09-2013 08:27 AM
Is there any information like this for the rv042 v1 hardware? That might help me as well.
02-24-2015 08:11 PM
So the answer to my original question, which I recently tested on a rv016 v1 hardware v3.0.0.19tm firmware, the maximum site-to-site vpn throughput I was able to get via iperf was between 45-50+ Mbits/sec, which is also the fastest I found it can do on the WAN.
What surprised me is that it bested a current model Netgear FVS318N which could only do about 20Mbits/sec on the same VPN test.
Newer isn't always better. ;) This almost 10 year old rv016 will return to service this year.
