07-04-2021 11:34 AM
I have the latest firmware on both my switch and router.
I have two patch cables between the router and switch and a LAG configured to bond them. I cannot get from active/standby to active/active even though I've been able to configure active/active on other LAGs on my network to other devices. It is something that the RV260 doesn't support?
07-04-2021 11:57 AM
- Apparently it should - ref : https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/kmgmt-2482-port-settings-RV160-RV260.html
Check Step 11 in this document, also is there anything in the logs when you try to 'activate' the intended lag-configuration ?
M.
07-04-2021 12:49 PM
Can you post a screenshot of the LAG config from RV, and show run from CBS from cli.
